I'm going to replace T&G wood cladding with uPVC on the outside of my house. I suspect there will be minimal insulation under the boards as it was built in the late 60s
The boards are nailed to a frame and on the other side (inside) there is plasterboard.
I would like to fill the void with foam board (the type with foil either side) which is inserted between the frame uprights. Should I leave a gap either between the plasterboard and foam board or cladding and foam board?
Should I also fit some form of polythene sheet between the cladding and foam board to resist moisture?
Any advice welcome.
Any advice welcome.
