How to join 2 pieces of timber
7 Feb 2008
I am building a pergola. The 2 main beams are 150 x 50 and the cross beams (15 of them) are also 150 x 50.
Rather than just sit the cross beams on top of the 2 main beams I thought I'd cut a peice out of the cross beams (say 50mm deep) and then slide them onto the main beams, this will look better but add stability I'm sure.
How do I cut these peices out?
I guess; use a jigsaw to make 2 cuts into each of the 15 cross beams - 50mm in depth and 50mm apart. Then get a wide chisel and knock the peice out?
Any advice would be appreciated.
that's the way I did mom's.. well ok i used a circular saw rather than a jigsaw, but the principles the same..
