I’m quite confused. I can’t find any info about this online…
tiles have holes in to screw them to battens. When overlapping tiles the top tile cover those holes on the tile underneath.
But all the tiles I looked at online don’t give the dimensions of hole distance from top.
So how do I know what the overlap distance is in order to work out how many tiles I need? Are the holes a standard or maximum distance from top that is known by everyone?
I’ve found online recommended overlap. For example, one site suggests 100mm is ok. So based on that I assume the holes are less than 100mm from the top. As long as they always are then I can work with that. I just need to know the overlap I choose covers the holes on the bottom tile.
