So, as I understand it, Elastilon has elastic properties and pulls the wooden planks together, even as the wood expands and contracts. If that is the idea, when I am laying it, am I meant to stretch the elastilon as I pull out the plastic cover sheet so that the sticky surface, then exposed, is under tension as it sticks to the underside of the wooden plank?
Thank you
Thank you
