OK folks, here's the plan. I'm laying laminate flooring throughout the upstairs (including stairs). Below is the layout (excuse the 2 minute paint drawing).
Right, i've laid the flooring horizontally (as you look at the pic) in bed 1, starting at the doorway threshold and worked upwards.
Once I've done the stairs, I'm going to be doing the landing and bed 2. The thing is that for continuity I want to run the boards (again horizontally as you look at the pic) from the landing into bed 2 in one strip (i.e. no threshold trim). I've cut away the bottom of the door casing in bed 1 and planned to do the same on bed 2, but can't work out how i'll get the boards underneath the casing on the corner of the bathroom wall. You have to lift the boards so that they click in place. Hope it is clear what the problem is. Any ideas?
