I'm drilling several 25mm holes in concrete block walls for plastic water pipes. Total wall thickness is about 300mm including cavity. I have a 1500W SDS Plus drill. I've never done this before.
I bought a 28x300mm diamond core drill bit and used it in hammer mode as instructed by the man in the shop. I got through five blocks successfully before the cutting segments completely disappeared. I've now read that this type of bit should be used in rotary mode only. Actually I tried that, and it seemed to make no impression on the block at all. At least hammer mode makes a hole - though it takes several minutes to get through a block.
Before I go and buy another one, is this the best tool for the job? I notice TCT core bits are also available. Which is better, TCT or diamond?
And how can I avoid rapidly destroying the bit?
Thanks Phil.
Thanks Phil.
