Sounds daft but I've measured my radiator that needs replacing and its width 48cm and length is 75cm - I've looked online and there isn't a single radiator that fits these measurements, so do I round up to one thats 50cm by 80?
Thanks for quick reply, so with the mm measurements online, I get one for 800/500 as they seem to list height first? Sorry but have a hole in current one and need to get a new one asap and its all new to me. Thanks again
Am I allowed to say "oh bugger?" re the pipes bit.
Is there anything I can do in the meantime about the hoel thats dripping water out? I've turned off the valve on the right hand side that lets the hot water flush in (heatings off too at the mo as its daytime)??
