- Joined
- 10 Apr 2016
- Messages
- 92
- Reaction score
- 5
- Country
Hello forum,
I want to test whether some 25ish years old copper pipes (cold water, hot water and radiators) are sound - no small leaks.
The water system is open vented for both - cold/hot - and central heating.
I have all the necessary isolation valves in place.
I do not want to pressure test above current gravity pressure (two storey house) so assume about 4 metre - 0.4 bar in order not to damage the pipes or connections.
What test method should I use? "Dry pressure" with air hand pump connected somewhere or other test systems (some mentioned water pump) ?
Many thanks
Many thanks
