How sticky is a two coat (2:1 ratio) SBR primed fibre-cement board floor?
We need to move furniture around the room (once the layer is dry), as we do the two layers. How sticky is the SBR primer, and what could we place over it, to protect the furniture (stop it sticking to the primer). What ever protection we lay, needs to be easily removed after, without leaving bits behind.
Because of lockdown, the carpet fitting was delayed, so we had to build the children's furniture in there while waiting. Carpets come this week, we will need to SBR prime the floor (two coats), so the underlay can be glued down. Flooring is GifaFloor FHB19 with wet UFH below.
