Hi I'm new here...
I have a 10 month old Vaillant ecoTEC plus 825 combi boiler which so far is excellent. I am refurbing my bathroom and putting in a new towel radiator and new valves and some pipework and so need to drain and refill the system. I have read both FAQs on this, but as the pressure is displayed digitally how can I check the pressure without switching the boiler back on? Is there an analogue scale (like a small Bourdon gague) inside, or do I just fill it until water comes out of a bleed screw, switch back on and check the digital display?
When draining down do I need to do anything to the boiler, apart from turning it off, as I've seen Youtube videos where the guy talks about 2 and 3 way valves in the boiler.
My draincock is on a radiator which is higher than the pipework I need to change so will I get all the water in the lower pipework come out when I cut into it, or will it syphon outside in the hosepipe?
Finally, is this boiler up to running a thermostatic mixer shower? I have a 2 bed flat with one bathroom and was told by the guy that flushed my new boiler that I had good mains pressure.
Any advice really appreciated, thanks for reading.
