How to remove circlip from SDS drill chuck?
11 Feb 2011
Dorset
A drill bit snapped off inside the chuck of my Titan drill. I need to remove the split ring around the chuck in the photo. I do have some circlip pliers but they are designed for circlips with flat ends and holes.
How can I remove this ring? Cheers.
These snap rings can be pretty awkward to shift, but how about two small electrical screwdrivers in the slot, and prising the ring open?
John :)
Thanks John, yes I tried that, but couldn't get the blades behind the ring. I'll give it another try. I don't mind getting a tool to do it if necessary. I expect the ring will ping off somewhere and be lost anyway, so my next question would be where can I get another one!?
Edit:- Oh I've just reread what you said, putting the blades in the slot and opening it out. I'll give that a try!
You can actually get the proper tool for these snap rings.
Very similar to a pair of external circlip pliers but with flat faces instead of pins.
I have used a pair of small, spring loaded pliers to good effect. The spring needs to keep the pliers in a closed position so when you are squeezing them the jaws open.
I filed the outer face of the jaws flat so they pressed against the ring ends.
Just prise the ring open enough to slide it over the collar. To re-fit use 2 screw drivers to slide it down and into the groove. You can then give it a gentle squeeze with pliers to tighten it up.
Do it in a clear poly bag if you can.
Saves ages looking for the bit if it goes flying.
