How to remove compression reducers
10 Dec 2009
Middlesex
Ive got a few rad valves with bodies for 15mm pipe work that have been fitted to 10mm pipe.
Im assuming they have been fitted using these compression reducers
http://www.screwfix.com/p/reducing-set-15-10mm/70435
when i come to replace the valves, how easy is it to remove the reducers?
can they be twisted off or will they need to be carefully cut off in a similar way to how you would cut off an old olive with a hacksaw?
