How to remove thick & cracked paint from an old door
30 Aug 2010
London
I've got an old door that I'd like to repaint. It's an external door to a building with flats, so ventilation is good. The old paint is cracked and has started to peel off. I don't know if it's lead paint or not. I presume I'll need to remove the old paint before repainting it. What is the best way of doing that?
Heat gun.
Paint strippers are not so good these days
I removed the old paint and sanded it back to bare wood. Do I need to use a primer and an undercoat before painting it white?
Coverstain is a good primer for new and old wood
I got Cover Stain and applied the first coat. The description says it may be used under any solvent-based or water-based topcoat. But the person in the paint shop said that it will peel off if I use a water-based topcoat. What is your advice?
I normally apply an acrylic primer over the coverstain but have also skipped this depending on the top coat i am using. Trick is to allow for coverstain to fully cure vs going over too soon .
The paint warms up under the influence of a building hairdryer, becomes soft. After that, the coating can be easily removed with a spatula. If the tool temperature is set too high, the base of the tree may be damaged. Different types of wood have their own limits of thermal exposure. Be careful!
Tree?
