How to repair plastic cold water pipe ?
9 Dec 2010
Middlesex
Drilled into the concrete floor of the wet room to install waste and hit a 10mm grey cold water plastic pipe coming from the kitchen to the sink of the wet room. I have no idea the manufacturer of the pipe.
What is the best way to repair this pipe/hole please ?
I could not find a pipe repair kit for 10mm only do one for 15 & 22
I was going to purchase a JG speedfit straight connector such as this one
http://www.toolstation.com/shop/Plumbing/Pushfit/Straight+Connector+10mm/d20/sd3143/p82662
and 2 pipe inserts as below
http://www.toolstation.com/shop/Plumbing/Pushfit/Superseal+Pipe+Insert+10mm/d20/sd3143/p86252
Will this do the job ? are these the right bits ? do I need the inserts ? If you could advice the right bits if not. Any special steps to carry this out ?
Many Thanks in Advance
Thankd adl ... this is what I have on the side of the pipe
RENOR-001/294 UNE 53415-2 EX PB 15x1.7mm B1. 000.5/1.0BAR. DIN
POLSKA INSTAL
Any ideas ? can i use any inserts ? as it says on web only to use pipe manufacturer inserts ? when can i get inserts for this pipe or should any inserts be ok ?
You will need considerable lengths of pipe exposed in order to get a plastic coupler onto the pipe.
Because of the way they grip the pipe its not possible to use them as a slip coupler.
An easier solution that I would use is a brass 10mm compression coupler modified to be a slip coupler. That would need no more than about 70mm either side of the damaged pipe.
A bodge alternative would be a 15 mm slip coupler with reducing insert to 10mm.
Tony
