I'm hoping someone can advise...
I want to replace two air vents in my flat. The air vents appear to be built into the wall, and are approx 10" by 7" in size. The property is a 1930's build, and the previous owner had sprayed some kind of foam filler inside the air vent, which has left it pretty much redundant!. As a result, the room suffers from damp due to the condensation build-up, especially in winter. Hence why I want to replace these vents.
It's possible to remove the foam filler, but I have to prise the air vent cover off first....
So. how do I remove these air vents?
Any constructive suggestions welcome!
Cheers, Ian
Cheers, Ian
