- Joined
- 9 Nov 2020
- Messages
- 5
- Reaction score
- 0
- Country
Hi.
Whilst stripping wallpaper in our utility room, I think I may have damaged our ST9400C controller. The clock is currently “stuck” at 3:30 Sun, with the override on the heating on. Pressing “ok” and “minus” for 8 seconds doesn’t do anything and I can’t find a reset option.
I’m planning on replacing it, and I understand that it’s a simple thing with all connections made to a separate wall mounted plate. However, when I power down the main CH switched spur, the backlight goes off, but the LCD remains lit. Is this because of the internal battery, and can I safely remove the front with the LCD on?
is there anything else I should be aware of?
