How to replace cast iron soil stack with PVC
28 Feb 2008
Sussex
Hi there, I was about to put in a new toilet in 1st floor batroom but as I was knocking off some old plaster from the wall behind the toilet a hole appeared on the soil pipe at the back of the loo! I managed to make a temporary repair but I obviously need to change the whole thing as the hole shows that the iron is corroded.The stack outside is cast iron and only has the one connection to the toilet I mentioned earlier. I know that you can slice off the cast iron pipe with an angle grinder and then reconnect a PVC soil pipe but can anybody tell me how difficult or easy it is to achieve.Thanks in advance.
I've got a 115mm angle grinder,is it good enough and can I use a regular metal cutting disc?
yes.sometimes its hard to get right through due to the grinder.
sometimes a wee hand grinder is usefull to get in at it
dont forget the goggles :eek:
