- Joined
- 31 Dec 2003
- Messages
- 173
- Reaction score
- 1
- Country
I have an old Kuppersbusch integrated fridge freezer (I believe Kuppersbusch shares many parts with Electrolux and AEG machines). The model number is 923 840 736.
I need to replace the door handle to the freezer (evaporator?) compartment and an online supplier 4ourhouse.co.uk can supply a replacement - part number 19930560H - but cannot supply any fitting instructions and I cannot figure out how to remove the old handle and fit the new one. Can anyone help please?
Some years ago I did manage to remove the freezer compartment door and replace it but I cannot now figure out how I did that!
I think I will need to remove the freezer compartment door and to do so will need to remove at least one of the plastic hinges but there doesn't seem to be any screws that I can remove - it looks like the bottom small plastic hinge is just pressed into the body of the appliance and the top hinge is inaccessible. Do I try to prise out the bottom hinge?
If I am successful in removing the door how do I separate the door in such a way that I can replace the handle?
Thank you
Thank you
