How to replace pump on hotpoint dwf61 dishwasher
20 Oct 2012
Staffordshire
The pump still works but the bearings make a wonderful noise when emptying. I have cleaned out the filter and removed the plate, secured by the screw,in the base of the sump and it still makes a noise.
So I have purchased a spare pump and turned the dishwasher over to take the bottom off and found its solid plastic! Anybody know how I get into the machine to replace the pump?
Thank you in advance.
Total strip down the door wiring and tub has to come out , not a nice job to do.
Remove the lid , side panels , door inner and outer then unscrew the. Salt pot spray arms and then tub comes out good luck.
Thank you for that. How long is that likely to take? The machine is about 10 years old so I might think about a new one.
I have only done 2 in 20 years and about 1 1/2 for me. I would say depending on your ability poss 4 to 6 hrs. Is it making a crunching noise in drain it might disappear after a few washes.
