Hi I am looking to fit a couple of pir controlled led security lights and an outside socket and have the switches already fitted on an outside wall, so I was thinking plastic conduit and twin & e inside or exterior cable, what do you recommend?
Ps the supply will exit wall at around 3m height and run horizontally to lights, the socket will also exit at same height then drop to ground level
