My pop up waste in my porcelain hand basin has recently decided to leak.
The water leaks between the chrome pop up waste and the bowl and runs away down the drain.
When I installed it over 12 years ago I am sure I used Plumbers Mate to bed it in with a large rubber O ring underneath the basin. unfortunately there is not a lot of surface area contact between the waste and the basin and cleaning fluids and constant pressure has probably forced any sealant out.
How do you professionals install wastes in hand basins? Do they come with a rubber/silicon washer or perhaps an O ring now? Do you use Plumbers Mate or perhaps sanitary silicon?
I would be interested in hearing before I remove it and undertake a repair
