How to Size a Radiator for a Small Hallway with Stairs to Small Landing
7 Dec 2023
Hello all
My House is a Small Semi Detached where upon entering the Front Door you are in a Small Hallway, maybe 2m x 1m with a Door to the Living Room and Stairs leading to the Small Landing with Doors leading to the Bathroom, Small Bedroom and Main Bedroom.
There is a Small Type 21 Radiator, 600m x 600mm in the Hallway behind the External Door.
I am not clear on how to use a Radiator Calculator for this Area due to the Stairs and the Stair Well etc.
Any advice would be welcome.
Thanks in advance
Kevin
Do it in 2 entities, hall to ceiling in bottom section, landing to ceiling in top section and just share out what's left over between the two on best endeavours process, add 2 results together to give overall heat requirement
Hello
Thanks for the Reply.
I did the Heat Loss Calculations for the Hallway and the Landing, the Results are:
Hallway: 265 Watts
Landing: 272 Watts
So, 537 Watts in all.
There is of course the Stair Well to also take into account.
I have a Stelrad Compact 600mm x 600mm (Type 21) in the Hallway, from the above I assume the Radiator would be enough since it is Rated at 807 Watts.
Thanks in advance
Kevin
