How to solve dip in chipboard floor?
6 Feb 2006
Somerset
In the hallway there is one section of chipboard which has dipped slightly and it can be felt when you walk over it. The chipboard isn't damaged and seems as strong as the rest.
What do you think has caused it and how can I level it out [levelling compound on chipboard??]- I'm hoping not to have to replace the whole board....
I fear you may have the same as me :cry:
The chipboard slabs have tong & Groove edges. If the joint between two slabs does not fall over a joist, the joint is unsupported, depending only on the strength of the T&G... which can break. The chipboard then cracks and sags.
To check if this is the case, see if your "dip" is at the joint between two slabs. Then look for the rows of nail heads (which will be over joists) to see if the joint is over a joist. If not.... same prob as me... need to cut out the affected area, and put in a new piece supported by a joist at each end.
The dip is not at the position of a joint, it is about halfway along a length of chipboard which is otherwise ok.
assuming the joists are at 400 centres firmly fixed correct size and the chipboard is flooring grade firmly screwed down it wont move
so if your joists are fixed without movement you floor is at fault
and if your flooring is correctly fitted your joists are at fault
it has to be one or the other or both!!!!!!!!!!!
Big All, I agree, but he is also asking how to fix it.
I suppose lift it up & support between joist or whatever is necessary
yep your right :rolleyes: ;)
should have said take a look and tell us what you see :oops:
