How to square of sheets of Plywood
8 Nov 2014
Yorkshire
Hi all,
Please bare with me and forgive me if this is a stupid question .
I have several large off cuts of plywood and would like to build a drawer unit with .
The problem I have is none of the corners on the sheets are 90 degrees and I cannot figure out how to cut them down to enable me to start off with square boards . An exaggerated version is pictured below.
I thought that if I use a framing square from one edge that would give me a reference point to square from but that didn't work out properly .
I have a speed square , framing square and a circular saw , with a diy straight edge guide , that cuts square if that helps.
Any help or advice would be much appreciated
Many thanks in advance
Glenn
you need to start with a strait edge so make sure you have a strait edge before marking
once you have a strait edge go central with your roofing square draw a line flip the square and draw a line beside the other one to check the square
