So i have a shower cublicle similar to this:
One of the column showers has broken, the thread on the shower cubicle that holds the shower head has a crack in it now.
I've been to plumbing merchants and Pipe Center, they have advised me to use super glue instead as the screw on compression nut is not going over the tap inlet (T shaped white tap) and there is no guarantee if they can match the thread on the shower head.
So I wonder if anyone can advise some good quick setting adhesive that acts as a sealant too (so it can be waterproof).
I've found this so far but wondered if anyone knew something better:
https://www.screwfix.com/p/araldite-2-part-epoxy-adhesive-tubes-opaque-2-x-15ml/2457h
Thanks in advance.
Thanks in advance.
