How to stick ceraminc tiles to a Wooden wall.
2 Jan 2006
I having some problem with my wooden wall where by the ceramic tiles are starting to give way. Wonder if anyone could advise how to stick the ceramic tiles back to the wooden wall? What adhesive should be use?
You need to use a flexible adhesive for wooden floors. i would go to a good tile shop and they wil sort you out with the materials Remember to add adflex to the grout also from the tile shop. good luck
Hi - looks as if the post: PVA and why you shouldn't use it as a primer - may give you a clue - to do with moisture absorbtion from the adhesive. Scared me when I read it! See beginning of this section and subsequent thread. Best Wishes
