- Joined
- 17 Feb 2006
- Messages
- 375
- Reaction score
- 2
- Country
About to (maybe) do some soldering, on 15mm pipework, using solder-ring fittings. I've done a bit of soldering before, the torch is a nice Rothenberger. But I'm not vastly experienced, so I think that I tend to use too much heat (though I could be wrong). The only joint that's leaked was joining onto existing that still have some water in, which ran back.
This I'm about to do will be joining onto existing, but vertical pipework. So I can drain it at least until it goes vertical. Though I'm still nervous about water residue making steam or something.
Anyway, the question. If you're solder a solder-ring fitting, what's the nearest you'd be happy working to an EXISTING soldered joint on the same pipe? Presumably a wet rag round the existing joint might help to dissipate heat. Or is there some sort of heat sink available?
Thanks in advance.
Thanks in advance.
