Hi all
I have a hot water issue where the boiler is turing OFF after 30 seconds for 10-15 seconds even when the flow rate is constant. I've been advised to check and clean/ replace the secondary heat exchanger..
I've managed to take off the panels, take the electrical connectors of the fan to get to the heat exchaner but can't take the fan off...
It seems its stuck on to the exchanger whereas the manual says carefully "withdraw" the fan from exchanger and then from appliance... I can't even move the damn thing, there seems to be some yellow paint/ rust like layer formed outside at the point where the tube frame of fan goes into the exchanger...
Any idea how to remove this please? Its a RAVENHEAT HE85 T combi boiler... I was thinking of ringing them up but they only answer technical answers to CORGI registered professionals..
Thanks in advance.....
