Hi all,
I was hoping someone might be able to advise on the way to test an NTC thermostat as used on my Diplomat ADP8902 (and some Smeg machines too) - it's this one: http://www.espares.co.uk/part/dishw...76/0/970446/970318/dishwasher-thermostat.html
I've tried testing it for continuity but am assuming that as it is, in essence, a heat-activated switch, then the fact it doesn't have continuity is not an indicator of whether it is working.
I set my DMM to resistance, and am getting an infinity reading (display reads 1) at room temperature and when I put the thermostat in boiling water. Would this indicate the 'stat is at fault?
Reason I ask is that I bought a new one to try and cure the problem with my dishwasher (if you want to read more, check out my other thread //www.diynot.com/forums/applia...asher-not-progressing-finishing-cycle.350854/, but this hasn't cured the problem and the new one returns the same results right out of the box as the 'old' one did...
Many thanks in advance for your help.
Andrew
Andrew
