How to turn off hot water
8 Jun 2017
Hi
I have a hot water cylinder but can’t see a way to isolate it
The cylinder keeps itself full and to a set temperature. I can turn the main water feed off but if there is a leak there seems to be no way to stop the hot water exiting the tank
Am I missing something? There is a mains tap above the meter.
Turning off the cold water feed to the cylinder stops water from coming out at the top,to go to hot taps . Does that answer your question ?
Makes sense now! I assumed there would be a shut off for the hot
Thanks for your help
