Dear experts,
I have a cupboard that at one time must have contained a hot water cylinder. At some point is was removed as the flat now has a combi boiler.
The cupboard has various apparently-redundant pipes and wires which I would like to remove to increase the available space and make it look tidier. The wiring includes a square metal junction box and three metal conduits; the junction box has a long terminal block strip with complex connections and many yellow or white wires. A quick check found none to be live. My guess is that this is the old wiring for the central heating timer and valves, and probably the immersion heater, and that it is now all redundant.
What would be the correct procedure for establishing that it really is redundant and can safely be removed?
It is difficult to follow the wires and prove that they are not connected to anything because they go into metal conduits, mostly under the floor, which are hard to follow.
Thanks.
Thanks.
