In my girlfreinds flat she has and cooker hood that has never worked properly
The flat and all the cooker hood were installed and owned from new.
There seems to be some power going to it as the lights work as do the lights on the instument panel which come on when you try to operate the fan.
the problem is that the fan has never worked, there is just a very faint noise when you switch the fan on but the motor does not spin up
I decided to take this off the wall this morning and inspect it. nothing blocking the fan/motor so i can only assume its and electrical problem.
the hood has now been removed from the wall.
and ive observed the following. there are 2 cables coming from the unit.
one grey outer with 3 wires: an earth, live and neutral (green/yellow, brown & blue), the other is a black cable with just two wires: a live and neutral (brown & blue)
i connected both of these up to separate 13a plugs and tested them... the former opertates the lights and control panel. the other does nothing.... both together blew the fuse on the live and netral cable!
When the hood was installed it was wired to a 4 way block.
connected to the block is a live neutral and a earth which go to a non swicthed FCU. There is an additional live neural and earth which i think go to the main fusebox or main circuit for the house, also coming from the main circuit is a single yellow wire which is connected to the last part of the block.
when it was all connected up the earth, live and neutral on the grey cable coming from the hood were connected up to the corresponding connections on the block.
both the blue and the brown wires coming from the black cable on the hood both connected up to that single yellow cable coming from the mains circuit.
can anyone tell me how if this sounds correct and what the single yellow cable would be for? also how would i correctly wire this up with the connections that i have
ive looked all around and inside the hood and there seems to be no markings, model number or anything to identify it. and typicaly the misses has thrown out the instuction manual!
Many thanks
rob
Many thanks
rob
