T
teaboyjim
I've heard builders say it's acceptable to mix fairy liquid with mortar?
Very diplomaticIt helps clean the mixer
Thanks for the linkCowboys use it as a plastiser.. https://www.designingbuildings.co.uk/wiki/Plasticiser
The only problem is that it's very easy to use too much, otherwise there is no problem and it does exactly the same job as any other entrainent.
That's the problem with washing up liquid. It doesn't tell you on the bottle how much to use per Cwt of cement. Unlike Plaz.The only problem is that it's very easy to use too much, otherwise there is no problem and it does exactly the same job as any other entrainent.
Who reads instructions anyway?That's the problem with washing up liquid. It doesn't tell you on the bottle how much to use per Cwt of cement. Unlike Plaz.
I will when I learn to read.Who reads instructions anyway?
Especially for Number 2.^^ nothing wrong with any of those, so A fairy is acceptable.
