How water pressure slows when cold tap is turned on...
9 Oct 2010
Antrim
Just changed my taps on the sink and bath lately and I always had a poor hot water stream as it is but now it is more noticeably weak when I turn the cold tap on at the same time.
I am guessing all taps are different and my new taps allow more cold water pressure through thus decresing the hot water pressure more - can this be rectified?
Thanks Andy,
No mate but we have a heat pump underfloor heating system? Had a plumber out before who said that if he increases the pressure to the hot it loses temperature so that would be the same idea as a combi system now that you mention it.
But why would the water pressure to the hot tap in the sink have dropped more since I change the taps? Just characteristic of new taps?
You need to learn the difference between pressure and flow!
You have bought taps designed for a higher minimum working pressure.
Either get your water supply uprated, buy new taps or live with it!
Tony
