Whilst sapele is often called African mahogany, and since WWII has been widely used as a mahogany substitute, it is a completely different genus, Entandrophragma, whereas true (i.e. South American) mahogany is genus Swietenia - both theses geni(?) are of the same family, Meliaceae, hence similarities in outward appearance. (And yes, I had to look that up to confirm I wasn't writing utter tosh as well as get the spellings right!)Have bits of it scattered around the boat, think it is part of the mahogany family, certainly same graining and colour and a hard wood.
Unfortunately this is all I have at the front now.If you're using it for a front door, it will presumably be stained or varnushed and it will need at least an open porch to protect it from the weather.
You are unlikely to find a solid one, most likely it will be "engineered" ( veneer glued to scraps of softwood or board formed into a slab )
Thanks, are there any upgrades to it in terms of durability/weathering that arnt hugely more expensive?Whilst sapele is often called African mahogany, and since WWII has been widely used as a mahogany substitute, it is a completely different genus, Entandrophragma, whereas true (i.e. South American) mahogany is genus Swietenia - both theses geni(?) are of the same family, Meliaceae, hence similarities in outward appearance. (And yes, I had to look that up to confirm I wasn't writing utter tosh as well as get the spellings right!)
Basically, sapele has all but replaced mahogany in most "mahogany" joinery and furniture products since WWII on the UK on the grounds of cost and availability. Sapele is more rowed with a greater chance of interlocked grain than real mahogany (which basically makes it more difficult to hand plane well). Sapele is still often used in high grade fire doors (as the veneered ply facings), including exterior grade doors where it is reasonably durable. Generally ranked as medium durability - so better than softwoods, not as good as oak, not a patch on teak or iroko
BTW products using it are often sold (mislabelled) as "mahogany" or "sapele mahogany", possibly in part because real South American mahogany is very difficult to find these days.
Paint is durable, but stain less so and varnish not.Cool, so as long as I give a new coat every few years I should be fine even with my crappy porch? Good to know, thanks.
