Just bought a new house and found that the brick shed/outhouse has power going into it. However the cable isnt buried in the ground but instead comes out of the cupboard under the stairs where the CU is, heads outside, along the wall to the corner, then up the wall about 4ft (the ground floor is approx 5ft higher than the garden) goes through the air to a post fixed to the shed and then down this post and into the shed.
As far as I am aware the external wiring should be buried 18" deep but i dont know what the rules are regarding power cable spanning gaps between buildings.
