Just helping son to fit Howdens kitchen units.
The integrated doors for washer and dryer are not pre drilled for the hinges, is this normal or have I just been unlucky?
I suspect I do not have the appropriate sized bit
If the door is used on an integrated appliance then it usually hangs of the front of the appliance. If it's to cover a dryer or washing machine then it's usually a standard door. You may have been given an appliance door (no hinge rebates) rather than a standard cabinet door.
The hinges for the appliances are different than for normal doors, and the spacings of the hinges are different. I would have thought that Howdens could have taken this into account and pre drilled them accordingly
The drilling for the hinges has to be spot on for position and depth otherwise door could be ruined.
