Hi guys,
I'm new to the forum and i'm having a new kitchen built, I wanted to know if any of you more experienced folk were able to see if this quote was fair? Also, wanted to check if there's anything in there that we don't really need.
I have already decided that i won't be using the Howdens appliances so they can be ignored.
The quote is for the Glendevon Cream
Many thanks in advance
Mini
1 GLR5851 Glr Wh Nh 300 CC Curved Base End 82.94 200.00
1 GLR5146 Glr Wh Nh 600mm Cush/Cl 3 Draw 89.94 100.00 F
1 HYH8133 Dlx 600 Cutlery Tray 60.00 10.80
1 GLR5600 Glr Wh Nh 600 Buoh Base 70.00 81.30 F
1 GLR5211 Glr Wh Nh 400 CC HL Base 70.00 117.00 F
1 GLR5335 Glr Wh Nh 800 CC HL Cnr Base 70.00 155.40 F
1 RKC0600 Base Blanking Panel 800/1000 60.00 6.64 F
1 GLR5256 Glr Wh Nh 900 Cc Hl Base 70.00 178.50 F
1 GLR5904 Glr Nh 600 HL App Door 70.00 75.30 F
2 GLR5584 Glr Wh Nh 300 CC Larder Twr 70.00 432.60 F
2 GLR5221 Glr Wh Nh 500 CC HL Base 70.00 249.00 F
1 GLR5198 Glr Wh Nh 1000 3 Drawer Base 70.00 418.20 F
1 HYH8197 Dlx 1000 Cutlery Tray 60.00 22.00
4 GLR5421 Glr Wh Nh 500 Cc Fh Wall 70.00 372.00 F
1 GLR5451 Glr Wh Nh 1000 Cc Dbl Fh Wall 70.00 174.90 F
1 GLR5431 Glr Wh Nh 600 Ccfh Wall 70.00 113.10 F
1 GLR5861 Glr Wh Nh Cu.Cl Curved Fh Wall Unit 70.00 316.20
2 GLR5987 Glr Cur Cab Cornice/Pelmet Rtn Sq 70.00 72.00
3 GLR5922 Glr Plastic Continuous Plinth 70.00 155.70 F
2 GLR5929 Glr Plastic Curved Plinth Return 85.00 36.00 F
2 GLR5930 Glr Base Decor End 70.00 96.60 F
3 GLR5941 Glr Wh Nh Fh Wall Decor End - 752mm 70.00 117.00 F
6 GLR5950 Glr 2130 Tower Decor End 70.00 750.60 F
5 GLR5911 Glr Nh Sqr Profile Cornice/ Pelmet 70.00 186.00 F
1 RKC0480 110 Degree Hinge Pack 60.00 2.60
1 HKC0055 Soft Close Kitchen Hinge Pack. 60.00 6.80
1 SNK5122 Lamona Rutland 1.0Rev Cw Waste 60.00 113.60
1 PLU5000 Sgl Bowl Dlx Plumb Kit/Twin App 60.00 15.60
1 TAP3521 Garda Swan Neck Tap 60.00 158.40
3 WKP2860 American Pecan Sq Edge 3m 616 38 60.00 362.40 F
1 WOR9039 Brown jointing compound 60.00 6.44
2 WKP2895 American Pecan 5m Edging Strip 59.99 46.40
3 GIR0026 Zip Bolt 59.93 7.20
1 ACK1295 800mm Full Extension RH Corner Unit 75.00 240.25
1 APL2806 Flexible 125mm ducting kit 60.00 18.00
1 LAM1160 Lamona 4 Burner Proff Gas Hob S/S 77.32 100.00
1 LAM8601 Lamona 60cm Dishwasher 94.42 50.00
28 HKB1255 Sq Bar Handle 94.99 9.80
1 ZZD39 Delivery 0.00 70.00
1 HJS9787 Kitchen Installation Manual August 0.00 0.00
1 GLR5920 Glr Continuous Plinth 85.00 25.95 F
1 LAM3401 Lamona S/S Single Fan Oven 71.77 175.00
1 SKD4254 G/devon Cream 600 Tall Door 70.00 72.00 F
1 HJA2420 Lamona S/s Glass 60cm Chimney Extr 77.22 200
the final price comes in at 7580.74!
The discounts have ranged from 60 - nearly 95% in some cases as far as I can tell
Mini
