Hi all,
I've had an issue for quite some time, and wondered if anyone has a suitable solution, given the water pressure that this pump puts out.
So, the issue is, that we have our pump permanently connected to a waterbutt, however when the pump has been on, we're seeing that there's a siphoning of water coming off when the pump is switched off. Hozelock have made a suggestion, of attaching a microbore hoze at the highest point of the output hose, but it doesn't appear to work, and we end up with a stream of water shooting out as a result. I've attached the file that I was sent by them.
I wondered if anyone has an ingenious way of overcoming this issue, which I could try?
Tony
Tony
