Just a question out of curiosity, what would happen if you put a high pressure sodium bulb with a built in ignitor into a normal light socket with no ballast?
That's what i was wondering, would the lamp ignite and if so would it fail catastrophically when it could not handle the current it was trying to draw.
What voltage to HPS ballasts normally put out when the lamp is fully warmed up?
What filament? There isn't a filament in a discharge lamp like a SON!
Philips datasheet quotes 90V & 0.98A for a warmed up 70W SON lamp.
If you put the lamp in a normal fitting ie. without a ballast you tend to get a brief flash in the arc tube and then ....nothing! However it is possible that the arctube could shatter & cause the outer glass to explode so I wouldn't recommend you try it! If you really wanna see what can happen... google photonicinduction and see his Youtube pages .... that guy is mad!
There used to be a self ballasted mercury lamp available that ran in a normal BC lampholder and used an internal tungsten filament lamp as a crude ballast. Philips and a few others made these in the 70s & 80's. I think I may even still have one.... somewhere.
It blow the fuse. My wife routed through my garage looking for bulbs lucky only a blown fuse there were also loads of 110 volt bulbs there so could have been worse. Good reason for 3A fuse in standard and table lamps.
The bulb won't strike because it relies on the inductive ballast in combination with the ignitor to generate a high enough voltage to ionise the gas. Without the inductor, there's no storage of energy to boost the voltage any higher than the peak of the AC waveform.
The ignitor will light up till the contacts switch and then it will be in a dead short across the supply, it'll probably blow the lighting circuit protection and will kill the starter in the lamp as it isn't made to take that amount of current, probably in short circuit so it is bin fodder.
