I've just got around to investigating our bathroom fan, and determined that the humidity + PIR + plus timer module has failed. It's one of these modules 72573901 Icon. Mk 1 eyeball, followed by meter, suggests that a 100 Ohm resistor has failed - slight burn mark on it, plus open circuit. The resistor is in the live supply to the entire module, the fan, and the shutter wax module - which appear to be controlled by a triac, and appears to be just a 1/4 watt. The 100 Ohms, seems to be too low a value, I see brown, black, black, black, space, brown - which I interpret as 100 Ohms, 1%. Is my interpretation of the value correct, please? It's R23 a discrete, on the front of the pcb..
Everything, on a quick look, appears to be supplied via this single resistor. What I plan to do, is replace the single resistor, with a pair of 200 Ohms, in parallel.
