The forecast today is (Humidity 56%)
that makes setting a fan to come on at 60% rather pointless.
How do I set the humidity setting in my bathroom extractor fan?
PS, check out the weather forecast. The forecast today is View attachment 117972
that makes setting a fan to come on at 60% rather pointless. It will spend most of its time just running because that's what the weather is like in the UK.
That is the forecast OUTSIDE humidity.
The RELATIVE humidity of that air will be much less once it is inside and warmed up.
in the house the air is warmer but has more moisture in it, from outside less moisture, but cooler.
Do you not understand relative humidity?)
Make???
Model???
You didn't even think to offer up the make and model in your opening post, so how do you expect us to help you, if you cannot even be bothered to do that? Some people are just too lazy.Thanks for the manual. I didn't have it and didn't think of looking for it online using make and model.
The trick is to read and understand the manufacturers instructions of the equipment you have, not all fans are the same make and model, therefore do not all adjust the same. So without this valued information, it would be impossible to help us or yourself.How do I set the humidity setting in my bathroom extractor fan? There's a tiny screw but it doesn't say how much to turn or how to end up at say 60%.
