I have a weird problem with my own heating system which I'm at a loss as to how to cure.
Boiler: Vaillant 418; Pump: Grundfos 15/60 on speed 3; System plan S-plan+
The problem is a gentle (but clearly audible) humming sound which comes and goes. This is a new problem in the last few weeks and it seems to be getting louder.
The noise is not combustion related - if i turn down the boiler stat the gas valve clunks shut but the noise continues.
If I turn the system off the noise stops as soon as the motorised valve closes and it goes onto pump overrun through the ABV.
If I turn the pump to speed 2 the noise stops but then the boiler decides it doesn't like me (doesn't modulate properly and goes onto short cycle).
All pipes are securely clipped and the system is (very) clean.
Anyone have any ideas before I swap out the pump?
Mogget.
Mogget.
