I've just moved into a new house and something doesn't seem quite right with the heating system: if I turn the hot water off, and the central heating on, the hot water will turn on as well.
I have a regular boiler (Potterton Prima F) with a vented cylinder. There is a mid-position valve by the cylinder. By the boiler is a programmer (British Gas DCP - like a dumb Hive), thermostat in the hall and thermostat for the cylinder.
My guess is it's something to do with the programmer or wiring, as when explicitly setting the HW to OFF and CH to ON, on the programmer, it shows the status for both as ON:
This is the same if the CH is set to come on using the schedule, the HW will also turn on, despite it being set to Always Off, or set to come on at a different time.
Here is the wiring behind the programmer:
And a few more pics, in case they help:
Behind hall thermostat:
Behind cylinder thermostat:
Can anyone see anything wrong here?
