Just a question (probably sounds dumb) but to put my mind at ease after reading through some posts on here lately.
If a cylinder stat or an immerson heater thermostat fail (on an opne vented system) - the water will probably boil (unless the thermostat on the immersion heater was a newer model and had a cut non-self ressetting cut out device and the heater simply wouldn't heat). Would this mean water would be coming out of the primary vent pipe and into the CW tank?
Otherwise how else would you know either had failed?
