HW Problem
10 Jan 2004
Just wondered if I can get any Ideas from you,
I have a problem with my HW, I woke up early yesterday morning with a horrible humming sound and the sound of rushing water in my pipes. So I checked my HW Tank cupboard. After a few hours working things out this is what happens.
I switch my HW on at wall, the over-ride switch on the motorised valve moves to the open position which turns on the pump running fine. The problem is when I want to switch off. When I switch off at the wall, the over-ride switch moves to the off position and then you hear a rush of water and a humming noise. If I move the over-ride switch manually in the cupboard the HW switches on and the noise goes away but obviously the heating is still on.
To swith my HW off I need to hit the switch on and off at the wall until you hear the humming noise stop and pump stopping.
My system is an Ideal elan 2 boiler with one room thermostat for the house with 2 of these valves one for HW and Heating. The heating works perfect.
Let me know if you can help or you need me to try out some things.
Thanks and Regards
