Hi
Sorry if this is a bit long winded, but I was wondering if anyone could help with some issues I’m having with my central heating system I’d be very grateful
We have a boiler downstairs (Ideal Classic, ACL Lifestyle LP722 programmer, room stat, TRV’s on all radiators) which heats a cylinder in the loft. There is also an ACL Lifestyle Mid-position valve, a cylinder stat, immersion heater (switched off) and a pump for the central heating up there.
We noticed some time ago that the water coming from the hot tap suddenly increased in temperature. This was back in April when we were still heating (set for hour in the morning, 3 hours in the evening) and at the time, the hot water was set for 1 hour in the morning and 2 in the evening.
Once we stopped heating (but still using the hot water), we noticed that the boiler would fire randomly throughout the day for short periods. We tried killing the mains supply to the boiler to re-set the programmer but it made no difference.
When I set both the heating and hot water to ‘off’ on the programmer, the hot water remains hot (we never run out), so the boiler firing during the day is keeping it hot. Every time I have been in the loft the mid-position valve has been sat to ‘W’ and when I try and move it, it ‘pings’ straight back to ‘W’.
Today I put both the heating and hot water on. The Mid-position valve stays at ‘w’ and the pump doesn’t kick in, or even turn over. The radiators have not got warm.
Other info:
- I’ve noticed that the water in the heating header tank is warm. It is not overflowing but there is a lot of sludge at the bottom of the tank.
- Cylinder stat is set to 50 degrees and is securely strapped to the boiler in a cut out in the cylinder insulation
- No work has been carried out to the boiler to coincide with any of the issues described above
Thanks in advance for any help you can give – pulling my hair out!
Steve
Other info:
Steve
