I'm planning on building a 1500mm wide dormer window into a 45 degree pitched roof. I'm at the 'design' stage and rather than going for cold/warm roof, I want to go for hybrid for space reasons. Is this likely to be a can of worms for the BCO, or has the world grown more tolerant of this approach?
I'd like to take the same approach with the walls: 100mm deep full-fill PIR between joists pushed tight up against the outer skin, and then a continuous 50mm PIR over the top - no air gaps. Does that seem feasible?
Gary
Gary
