Hydro Spartan - adding inhibitor
6 Nov 2009
Essex
After using this forum a few years ago to identify a Hydro Spartan in my house (link below), I have a new question regarding this set up.
//www.diynot.com/forums/viewtopic.php?p=1397317
I need to replace a pair of old leaky radiator valves, and while I'm at it, I will replace the radiator too, which is also old and inefficient. Obviously, I need to drain the system to do this.
On refilling, can I add inhibitor to the system? Through the new radiator, I assume?
I ask this because as I understand by reading other posts on here, you can't add inhibitor to a Primatic cylinder due to cross contamination. However, I'm assuming that although this Hydro Spartan is a type of Primatic cylinder, as it is used only to replace the F&E tank there would be no problem adding inhibitor in this case?
Thanks for any comments.
