I have a Sime Friendly format 80E and am having a wee problem with it.
When the boilder is required to produce hot water for central heating/ hot water taps it clicks on, and starts as normal, but within a few second the pressure rises and the boiler cutsoff i assume a safty mechanism. Anyhow, I bled one of the radiators to perhaps releive some pressure, even though its had already settled back to 1.5bar when it cut itself off.
I seem to be able to make it do this every now and then when I test it, and I really think its something internal, or perhaps a blockage somwhere.
Ive had the hot water and the heating working since the symptoms began this morning, but now I think its a repair job...
Perhaps someone in the know has an idea whats wrong with it, I'll be phoning a gas-safe engineer on monday.
Fault with high pressure building up on ignition and heating process start.
Boilet cuts off before pressure builds too high.
All other signs are normal.
Does the system perhaps need repressurised, or is something else perhaps now gone to fault, it has been 8 years since its last service
